VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Apr 11, 2023 12:50 pm
If it's only a few days or months past the warranty extension, you could ask the dealer to go to bat for you on a goodwill claim. The Service Manager will generally have the most say in whether goodwill is extended and how much it will cover, but Nissan will generally help out if the failure is egregious (which 50K is) and the dealer will agree to submit a goodwill claim.
I can't speak for the circumstances of the failure, but most premature ones are the result of either lead-footing or high transmission temperatures (for any of multiple reasons, climate, steep hills, trailering) coupled with no fresh fluid. Nissan doesn't recommend fluid changes the way they should in order to keep the official "cost of ownership" low, which I've always felt was a bad policy. It certainly results in a lot of unnecessarily-blown trannies which wouldn't happen with regular 30K fluid changes. There are lots of other threads in here discussing why, but the short story is that CVT's are inherently metal-on-metal devices, and that means when the fluid dies, so does the tranny, full stop.
