2016 Nissan Rogue AWD error
don_keyhotai
Car: 2016 Nissan Rogue
Hi, I just purchased a 2016 Nissan Rogue w/ AWD about 2 weeks ago. Yesterday, I was driving up an icy road to a ski resort, and the AWD just stopped functioning. I received messages that said "AWD Error - See Owner's Manual" and "Chassis Control Error - See Owner's Manual". Various warning lights also appeared - the 'slippery conditions' (or whatever it's called) light, the general triangular warning light, and the ABS light. The AWD definitely did stop functioning: it was slipping more and the graphical indicator showed no power going to the rear wheels. I had to turn back around and head to the dealership.
When I brought it to the dealership, they said that they had not seen this problem before and it sounded to me like, basically, the tech had cleaned off some sensor that controls the AWD. This doesn't sound like a permanent solution to me, and I'm now very concerned about the AWD just quitting again in the future. One of the specific reasons I got this car was because it had AWD, so if this feature is problematic, it's useless to me. Has anyone seen this issue before?
Thanks.
WILLDOGS
Car: 2015 Rogue SL Premium
One of your sensors in the wheel is either faulty or got dirty/iced up and couldn't properly judge your wheel slip and rotation.
Could just be a one off issue that never returns. Don't think its a common problem at all since this is the first complaint i've seen.
ArmedAviator
Car: 2012 Infiniti M37x
Wheel speed sensors are the usual culprit in these situations. They usually also affect ABS and traction control.
Maximus099
Car: 2014 Nissan Rogue SV AWD
Just yesterday while purposely make the Rogue slip and slide the "slipping" logo came on in the dash and lost almost all power for a couple of seconds. I guess this happens in order to try and regain control on the vehicule but cutting off power can actually endanger the occupants i think. I would need the power to kick the rear back in for example.
Return to “Rogue Forum”
