2016 AWD S - headlight fuse High Beam
fuzio1963
Car: 2016 rogue s
Under airduct fuse boxes (2), there is no any diagram on them.
I checked all the fuses, all are good but still doesn't have power in right high beam lamp.
I also checked fusebox in-cabin.....no diagram either.
Any advises ?
It's 2016 Rogue AWD S
fuzio1963
Car: 2016 rogue s
Really?? No one.........knows????
kboo74
Car: 2015 Nissan Rogue SL AWD Premium Pkg (Former)
2017.5 Nissan Murano SL Tech Pkg) (Former)
2019 Acura RDX A-Spec with Tech Pkg Performance Red
They have a FSM Manual available here on the site for a free download under the Service Manual tab. Your issue is with the headlight itself. Also have you tried using the search feature, I believe this topic has been covered before here.
Ken
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Try googling "2016 Nissan rogue fuse panel diagram". That is if you need to know where the fuses are, when it comes up switch to images, you'll find it. Before you do that are you sure you just don't have a blown bulb?
fuzio1963
Car: 2016 rogue s
I thought I have. But even it looked okay, I switched them, right to left. Both are good. Also I checked all (known to me at the moment ) fuses. Both boxes under air duct, and inside cabin panel. All are good....... I think I might go to the dealer.........what a shame......for a fuse? Seriously ?
fuzio1963
Car: 2016 rogue s
Anyone knows where to look for highbeam fuse (right side) in 2016 Rogue S AWD?
I will buy a case of beer if you show me...... :crazy:
Reason: Merged with existing thread
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
fuzio1963 wrote:I thought I have. But even it looked okay, I switched them, right to left. Both are good. Also I checked all (known to me at the moment ) fuses. Both boxes under air duct, and inside cabin panel. All are good....... I think I might go to the dealer.........what a shame......for a fuse? Seriously ?
fuzio1963 wrote:Anyone knows where to look for highbeam fuse (right side) in 2016 Rogue S AWD?
So instead of going to the dealership, you waited a month and started a new thread ??? :nono:
How did you determine the fuses were good?
Since you haven't bothered to search, here you go...
fuzio1963
Car: 2016 rogue s
No, I was in Europe last month - vacation.
And yes, all fuses are good, I took out and checked every single one.
According to the picture you sent.......which one is it?
And yes, if nobody knows how to fix it, I will go to dealer tomorrow.
Ty.
frijolito
Car: Rogue (Xtrail) 2020 Advance
I had a similar problem on my pathfinder, I checked all fuses and everything was fine... eventually I found it was a fuse missing, dealer couldnt tell me why it was missing, just was..
fuzio1963
Car: 2016 rogue s
So, Mr. moderator - I guess you do not know either.......
The picture you sent - what am I looking at?
I DID bother to search...........and saw that picture, but since it does not show what I am looking for, I posted another post.
There is no need to be rude, you know.......
Thanks everybody............
Rogue One
2022 Honda Pilot SE
fuzio1963 wrote:So, Mr. moderator - I guess you do not know either.......
And we're done here.
Return to “Rogue Forum”
