darrylwmiller »
https://forums.nicoclub.com/darrylwmiller-u302375.html
Mon Mar 03, 2025 5:06 pm
Back at it with more car repair fun. A couple weeks ago I started the car after coming out from a store and I noticed there was no air movement from the vents even though it was set to high. I assumed it was the blower motor and started driving - after about 2 minutes it came on and was working fine. Both cold and Hot worked as well as all fan speed settings. It has been fine since then, until today.
This morning same thing happened but after a minute it kicked on, but I feel like it was not blowing as much as it once did. I turned it off and back on, and it would start up right away. I left work today and the same delay in the blower starting, however this time when I turned it off and back on it would take a minute to kick back on. I did this several times on the drive home with the same result. Hot and Cold still work and all fan speeds seem to work once it is started.
I have the standard red and blue manual knob to adjust temperature and nothing digital but now I am not sure if it is the blower motor or something else causing this strange issue. Most threads I have read indicate the blower is not working at all.
Looking at Rockauto opens up more things I am unsure of. Blower Motor, Blower Motor control module / resistor, relay. It would almost seem like it would be easier to check if it did not work at all, haha.
Additional Note: I did notice periodically the fan sounded lile it was humming or running a little louder than normal. Almost with some faint clicking noise but now the aound is gone.
