amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Thu Dec 28, 2017 8:50 pm
Not if the car has no mandatory software update, you can then do it yourself. I'd suggest looking at the appropriate service manaul here onsite and reading the fluid change instructs there to see if no software update is involved.
The plug is merely a 2 piece one that in essence sets a level to fill to like a manual transmission does. One plug comes out to drain anything over the normal level, then the one around that one or a separate one located elsewhere then drains all in the pan. Two issues there, one, about half the fluid remains in the converter to not come out, two, you have to come up with some sort of handpump to pump the new fluid in since you have no dipstick tube. You pump in new fluid until it just begins to come out of the standpipe plug, whichever one it may be.
