2015 winter tire size
RoombaGuy
Car: ???? Nissan Rogue SL AWD
All
i'd like to put winter tire on steel wheels for winter. Ideally not 18' wheels ; 16's or 17's
How would I find recommended sizes I can use?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
just stick to whatever the 2015 rogue comes with, when you buy the entry level rogue.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Original Equipment Sizes for 2015 Nissan Rogue SL: 225/60-18 TireRack.com
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
Anytime you go down in wheel diameter, you want to increase the sidewall to try and maintain the same overall circumference. Keeps speedo and odo more accurate and helps prevent serious suspension & handling issues.
For a 17" wheel, you'd want a 225/65 tire.
For a 16" wheel, 225/70. ASSSUMING that the 16" wheel will fit. It looks like there is enough room over the brake rotors that a 16" would work.
The 16 is prob a better choice if it will work. More Winter and AT tire options and probably cheaper too.
Return to “Rogue Forum”
