burrpenick »
https://forums.nicoclub.com/burrpenick-u270395.html
Fri Mar 31, 2017 2:18 pm
Although I have not changed the oil yet, it sure appeared to me that it needs to be bent out of the way in order to get a good grip on the filter. SOmeone else posted that they partially loosen this panel when they do it but that it was possible to remove the filter w/out taking it off. BUT, now my question is the washer- I have not had to fool w/a washer on a drain plug for ages, but this new Rogue used one........I've usually be able to reuse them a few times, is that still the case, and, WHERE to get them other than the dealer?
