2015 Rogue SV Brake Lights Not Working (3rd Light works fine)
Tao1123
Car: 2006 Maxima SE
2015 Rogue SV
I did a search and didn't find anything specific to my issue. Currently when I press my brakes the third light will come on but the left and right lights will not. I am not experiencing any other issues and no indicators show on the dashboard. I have read a couple places that it could possibly be the brake switch, however, that doesn't make sense that the third light would still work. I have also read it could be a brake light relay, problem is I have no idea where this is located. Has anyone else experienced anything like this?
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
First things first, check the fuses. If the fuses are ok, dig out your trusty multimeter and have a helper step on the brakes and probe with the multimeter and see if you’re getting 12v to the bulb socket.
SetnraSR2018
Car: 2010 Nissan Sentra SR
Have you been able to fix the issue? I have the same symptoms in my 2010 Nissan Sentra. The taillights are on and light up fine, but when you press the brakes, only the third brake light brightens up, the left/right lights stay dimmed. I am travelling at the moment and would like to have an idea of possible solutions. I did rule out the fuses and bulbs.
Return to “Rogue Forum”
