VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jan 29, 2023 5:56 am
No, it's not in the climate control panel, it's behind it. There's a small rack of relays screwed backward to the base of the centerstack, right behind the panel. The rack will have 2~3 relays depending on options, one of them is the Power Window Relay. You can identify it by wire colors, it will have Green and White coil wires and Pink and Blue contact wires. The Blue contact wire is window RAP.
