jumpin4abeat »
https://forums.nicoclub.com/jumpin4abeat-u210356.html
Sat Feb 28, 2015 7:23 am
I was curious if anyone has found any information on the wiring for the non-bose radio as well as the removal process. I am installing a small sub and do not want to tap into the door speakers for the converter. I had a 12' rogue and I was easily able to remove the radio and place the converter into the pocket behind the radio. Even when I had to remove that radio it was easy to do. It seems as though in the 2nd gen model they make it impossible to just look around and figure out how to remove components. I wish haynes would come out with a 2014-2015 manual. If anyone has added a sub can you let me know what wire colors are for the front door speakers and if you had trouble accessing the harness.
