2015 Rogue fuse box under dash
jahite128
Car: 2011 Rogue Sv
2013 Rogue AWD SV
2015 Rogue SV AWD
Trying to wire up Genesis Homelink Mirror. Have Rogue without Moon roof. Pulled dn the Map light and courtesy light panel. All leds now, can't find 12v in assembley. Looks like need run wires to fuse box. Has anyone done this and can give me an help ?
PapaSmurf2k3
Site Admin
So you're looking for a constant 12v?
I'm surprised they don't have anything up there in the courtesy light panel. Personally, I would probably run a new wire to the fuse panel (or splice into a wire I knew was 12v already).
You can always look at wiring diagrams in the FSM though to see if anything pops out.
www.nicoclub.com/FSM
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
i have not done this in the new model rogue, but i have certainly done this in the 1st gen rogue. (running a wire from that area, to the fuse box, that is)
  • do you know the current(amp) draw of this mirror? you dont want to overload a circuit.
    did you already find an ample ground spot? if not just install a loop-terminal on the ground wire and a simple small self tapping screw will suffice. just make sure not to run that screw through sheet metal. only thorough a cross bar of some form. this way you wont drill through the roof lol
    when running the wire down, do so carefully, since you have side curtain airbags.
    choose a wire specific to the amp draw. for a mirror, i would probably say an 18guage will be fine.
    i would also install an "bussmann add a fuse" to the positive wire to not only protect your mirror from spikes, but to make a clean install in your fuse box. (i keep like 10 of these in various fuse sizes, in stock in my garage just in case i get bored one day and want to install something lol)
bussmann add a fuse:
buy it here: http://www.amazon.com/gp/product/B007FF ... 3XPPLUAOGC
Return to “Rogue Forum”
