2015 Rogue Blend Door Failure
subdriver606
Car: 2005 Nissan Altima
2005 Nissan Quest
2006 Nissan Murano
2009 Nissan Altima
2015 Nissan Rogue
My blend door actuator gear and blend door gear that meshes to it has grinded themselves and the door no longer moves properly. Is it possible to have just the gear on the blend door replaced without removing the majority of the dash and heat unit?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Nope. Short of replacing the HVAC unit, we've done a couple successful repairs using hard silicone or JB Weld along with vaseline to keep the parts from sticking where they shouldn't. A lot depends on how much is left of the stripped splines.
subdriver606
2005 Nissan Quest
2006 Nissan Murano
2009 Nissan Altima
2015 Nissan Rogue
Thank you
Return to “Rogue Forum”
