0_Live_Light_0 »
https://forums.nicoclub.com/0-live-light-0-u314084.html
Fri Nov 22, 2024 11:53 am
Yes - thought about that after I left the computer. Thanks for reminding me:
I don't know if other codes were tripped--just going by the receipt I was given for the inspection.
The typical dlrshp service receipt indicates (comparing these to other receipts provided by the previous owner):
"Upon inspection of veh tech found 2 codes present for P0420 and P0430. Based on codes present technician recommended replacement on catalytic converter"
However, attached to the dealership receipt is another printout with no company header/info--just blank, identifies 3 names for "service Advisor" (w/ dlrshp email), "Parts Personnel" (w/ dlrshp email) and "Service Technician" (who is also ID'd on the dlrshp page but is listed with only a personal gmail address...)
and the quote reads, "Exhaust Catalytic Converter Replacement: P0420 and P0430 are tripped showing internal failure in both catalyst systems."
Itemized list includes two manifolds at $1500ea; 2 exhaust gaskets, one man exhaust gasket and two front exhaust tubes at $1500 ea.
A second page behind this one DOES have a dealership info at the bottom and has a quote for a broken door latch.
Thank you for that explanation. I have read other threads and you have mentioned those points, which I now understand better in context. I purchased some cataclean and will add it pretty soon. I feel frustrated by the sequence of events, since the codes tripped literally less than 24 hrs after driving the car off the lot.
My (limited) understanding is that the cats increase performance, fuel efficiency and exhausted air quality although my car does not require inspection in this part of the country. I'm curious how to determine decreased performance? Are the cats just losing performance and efficiency or are they actually clogged? Shouldn't the sensors and/or the O2 sensors be evaluated? Shouldn't the temp of the inlet + outlets be measured or back pressure test be evaluated first before replacing them? Or would these steps not align w/ garage protocol of the dealership?
Thanks
