2015 QX80 brake bleed issues
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
jefe_de_estado
Car: 2015 Infiniti QX80
My front brakes have been squealing so I bought new pads and rotors. (Pedal felt just fine up to this point). While changing the pads I found the reason for worn brakes was that the slides were frozen solid, so I had to buy new calipers as well. Got everything installed and put back together.
Started with a gravity bleed on both sides. Then bleed the brakes like normal. (Open bleeder, depress pedal and hold, close bleeder, lift pedal, repeat). Did that a number of times. Didn't really see much air come out. But the pedal was still totally soft, drops right to the floor. Found a YouTube video that said you need to pump the pedal 20x, then bleed. Did that at all 4. Still soft pedal. Tried that a few times, still nothing. Finally read the FSM and followed that as best as I thought (it's a bit unclear). This involved bleeding the accumulator, then going FL, FR, RR, RL. Pump 20 times, turn on car, wait for accumulator to run (never goes more than 18sec), depress pedal (pump starts running), open bleeder, close bleeder, lift pedal. Turn of car, repeat 20 pedal pumps. Cleared out the C code that it would throw by pushing the pedal 20 times. Did this several times. Still nothing. I've gone through over a gallon of brake fluid (at least it's all nice and clean now!) and haven't seen a single bubble come out for quite a while. What am I missing?
After all this, the pedal goes right to the floor. I can get pressure if I pump 5-6 times. Then I'll start the engine, and it drops to the floor. With the engine running I can get pressure by pumping a few times, but then drops straight down. Seems like it might be a computer issue?? Thanks for any help!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Do you possibly have the new calipers swapped left/right? That puts the bleed fittings at the bottom and the pistons will never bleed out.
jefe_de_estado
They are pointing down, so sounds like a good chance of that. The boxes had no labeling on them at all, so there's a good chance that this is correct. Figured they would only fit one way, but sounds like it's possible to get them backward. I'll give them a swap in the next few days and report back.
jefe_de_estado
Turns out I was a big dummy, ha! You nailed it. Swapped sides and one quick bleed process and it's all set. The pedal feels much better than before, so maybe it was worth all the headache to screw it up and get a really good flush, ha! Thanks vstar, that was a great catch!
VStar650CL
Technical Expert
You're most welcome. Air rises and fluid sinks, bleed fittings are never at the bottom. ;)
Return to “Armada Forum / QX56 Forum / QX80 Forum”
