2015 QX60 Subframe question
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
sm2023
Car: 2015 Infiniti QX60
Can you remove the subframe without supporting the engine with a hoist? I want to replace the rack and pinion on my qx60.
Thanks in advance!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If the nose and transmission mounts are both in good shape, yes. If you have any doubts about your mounts, use a support bar and not a hoist. Much easier.
https://www.harborfreight.com/1000-lb-c ... 96524.html
sm2023
Thanks VStar650CL for responding to my question. I was able to get the rack and pinion out without messing with the subframe. I did remove an engine mount (which is at the center of the rack and pinion) and used a floor jack to support the engine while I was working under the car. Disconnecting the high pressure steering fluid line was very difficult. It is all done now!
VStar650CL
Technical Expert
:dblthumb:
Return to “Infiniti JX35 / QX60 Forum”
