Seems odd that they did not update the screen with the 2015 update given that the Q50 was launched with the 'In Touch' screens.IlyaKol wrote:Q70 started its life as the M37/M56 in 2011. However, my screen doesn't seem much different than my 2007 was.
I know there is a diagnostic mode for the screen...forget how to get into it. Perhaps if you can figure it out, you can get into the camera setting and tweak it.
Do you have an image of the output?
To get to the diagnostic screen;IlyaKol wrote:Q70 started its life as the M37/M56 in 2011. However, my screen doesn't seem much different than my 2007 was.
My point was to say that the screen is fine. My biggest issue is the camera gets dirty VERY easy. But right after a wash, the rear view is VERY nice (I see everything just fine).jayramq70 wrote:Seems odd that they did not update the screen with the 2015 update given that the Q50 was launched with the 'In Touch' screens.IlyaKol wrote:Q70 started its life as the M37/M56 in 2011. However, my screen doesn't seem much different than my 2007 was.
What kind of plug(s) does it use?Altered wrote:I plugged the Altima's backup cam into the M and it improved the image quality substantially but still wasn't as clear as in the Altima.
Find a compatible camera with better specs I'd imagine (and hope). Just a matter of figuring out what qualifies a camera as compatible.IlyaKol wrote:How does one upgrade the optics of the camera?
I allso have a Toyota sequoia,Debonair wrote:What kind of plug(s) does it use?Altered wrote:I plugged the Altima's backup cam into the M and it improved the image quality substantially but still wasn't as clear as in the Altima.
That was two years ago I don't remember lol. Similar plugs but the body of the Altima camera was different and wouldn't bolt up without cutting so I left it, plus the Altima was a lease I didn't want to mess with it.Debonair wrote:What kind of plug(s) does it use?Altered wrote:I plugged the Altima's backup cam into the M and it improved the image quality substantially but still wasn't as clear as in the Altima.
Resolution? Or contrast and brightness? Resolution is usually fixed.M37xfan wrote:Hello everyone, new to the forum.
I adjusted the resolution of the back up camera by doing the following:
with the Parking brake on and or foot on the brakes, put the car in reverse and press the Settings button. You should see settings to adjust resolution.
