2015 Q60 Coupe Factory Service Manual
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
mkrser
Car: Q40, Q60S,350Zsold
Hi. I have been searching for the FSM for the 2015 Q60 coupe on the website and can not locate it. Is it available? When I go under Q50 Q60 for 2015 it only has the Q50. Thanks!!!!!!!
rmyAddison
Car: 2016 Q50 Red Sport
The 2015 Q60 was the last year of the G37 body style with 3.7 engine (I had a G37 IPL). The FSM for the G37 probably covers everything you might need.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
mkrser wrote:
Wed Jul 26, 2017 7:39 am
Thanks for letting us know it's not there. We'll have to add to the list the next time we buy FSM's from Nissan.
mkrser
Hi. Thank you for the fast reply. I will be on the look out for it. I am new to this site and so far it's great!!!! My main concern is the procedure for resetting the drop down side windows if I have to replace the battery or disconnect it for any reason like cleaning corrosion off the terminals. My previous 07 350z was relatively simple but like to know what I am getting into if and when the time comes. If anyone can verify the procedure is the same for the earlier years G37 coupe I can access the info from those manuals. Thanks again!!! :)
mkrser
Hi. Thanks for the info and fast reply. I will check it out.
rmyAddison
I had a G37 IPL, the process for resetting the drop down windows, doing this from memory, was I believe lower the window, raise it, let go, then hold the up toggle 2 seconds, it should reset. Don't remember if you do this with the door open or closed, but one of them should work.
I remember going through this during a battery change when I had my G37 IPL.......... :)
Return to “Infiniti Q50 / Q60 Forum”
