2015 Pathfinder automatic tilt wheel not working
hargdude
Car: 2015 Nissan Pathfinder
I have a 2015 Pathfinder that has automatic tilt wheel and it does not work either on preset or when using the control on the side of the column. I have tried to find a fuse for it but no luck so far.
Is there a manual override? I guess it would be possible for both motors to go bad at the same time. It has no warranty so I am trying to troubleshoot this myself. Is there a wiring diagram available somewhere?
Thanks for looking.
Reason: Moved to correct forum
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO! Sorry to hear that your car is having trouble. I'm not all too well versed in your vehicle, but can offer an option for you.
Here at NICO, we have Factory Service Manuals available free to members. Here's the link to the STEERING SYSTEM FSM for your vehicle.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It won't be a fuse unless your mirrors and power driver seat are also inoperative. Those are all driven by the Automatic Drive Positioner module under the center-right dashboard. If there's a fault in the tilt wheel system, the ADP will have codes. You should get the ADP scanned by a dealer or a shop with a high-end scanner such as a SnapOn Solus that can detect the ADP system.
JayArras
Car: 2013 Pathfinder SL Premium (traded in)
2023 Pathfinder Platinum AWD
Rogue One wrote:
Thu Jan 07, 2021 8:14 pm
I wanted to ask you a question about that. Why do the manuals only go up to MY 2016 for the Pathfinder?
hargdude
VStar650CL wrote:
Thu Jan 07, 2021 8:49 pm
Thanks for the reply. The mirrors and drivers seat work fine. The tilt wheel is the only problem, it does not move at all.
