2015 Juke Nismo P2004 Code
The web's first forum dedicated to the Nissan Juke and the Nissan Qazana.
Glabadze
Car: 2015 Nissan Juke Nismo
I've got a 2015 Juke Nismo. Obd shows p2004 code intake manifold runner control valve stuck open. I changed two times intake manifold control valve actuator, but code comes back. I removed intake manifold to see but there is no carbon buildup, but there is a little oil on butterfly plates. Engine light is on and VDC light too. What should I do? Any suggestions?
Reason: TYPO
Is the boost sensor coated in oil?
Is that the only code (does it come back after being cleared)?
VDC light should show another, separate code. Let's re-scan it.
Glabadze
I haven't seen boost sensor. Yes it came back. Firts it was only p2004 than it came with p2018.VDC shows C1130.
Glabadze
AZhitman wrote:
Mon Dec 16, 2019 9:24 am
This guy's C1130 issue sounds like yours - especially since you had the manifold off and there's some funk in there:
https://www.jukeownersclub.co.uk/forum/ ... -dash.html
P2018 doesn't tell you anything, basically just a reminder that P2004 is an issue still.
Glabadze
AZhitman wrote:
Mon Dec 16, 2019 11:52 am
I know this exhaust pipe but it's only on diesel engines as i know.
Glabadze
Today i removed the Boost sensor an there was little oil could it be its fault ?
Return to “Juke Forum | Qazana Forum”
