2015 hatch won't open
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
cindyS1948
Car: 2015 Nissan Versa Note
My son has a 2015 Nissan Versa Note Hatchback. The hatch opens manually. It won't open. He has crawled inside and removed the panel, but can't seem to see what has 'broken' so that the latch will no longer open. Any suggestions on how to get the hatch open?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
This is the arm worked by the actuator to roll both the lock cam and latch cam, working it with the lock cam in the unlocked position should release the latch. If it won't go all the way then the actuator is probably stuck in the locked position, you may need to force or break it in order to let the arm move.
15 Note Hatch Lock.jpg (13.66 KiB) Viewed 1829 times
cindyS1948
would this apply if the latch handle moves freely and feels disconnected ?
VStar650CL
Technical Expert
If it feels disconnected but it isn't then you probably have a broken mechanism.
cindyS1948
How can we tell if it is disconnected? My son can't see or feel anything loose.
VStar650CL
Technical Expert
You can see the cable for the handle in the pic, it needs to be attached at both ends. If it's broken or has popped off at either end then it won't work the release arm.
Return to “Versa Technical Discussions”
