2015 door locks
Chkultr
Car: 2015 Nissan Rogue SV AWD
I honestly can’t find anything online at all about this issue.
Door lock button on driver and passenger side will not activate the door locks. Activate the right turn signal and the doors lock constantly unlock until you turn off the turn signal. Open the rear tailgate by power and as the flashers activate the doors locks unlock constantly.
Anyone else have this issue?
More importantly does anyone have a solution
Thank you to all in advance
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
That's definitely messed up. It sounds like your Body Control Module is messed up. What was going on prior to these issues?
As far as fixing it, you could try disconnecting the battery for a minimum of one hour, but if that doesn't work the BCM will probably need to be replaced.
Chkultr
Nothing else happened prior to this. Believe it or not we sat idle at a pop up drive in. Noticed it when we went to get out to use the restroom before we left.
I left the battery disconnected for a few hours. It still did it. I did replace the remote batteries and went on a test drive last night. It seems to be semi working. The door lock button works. They don’t constantly unlock when the right turn signal is activated. The auto lock didn’t activate but the Auto Unlock did.
Thank you for the response
Return to “Rogue Forum”
