2015 altima just stops
General discussion area for the L33-chassis Altima.
Tromeo907
Car: 2015 Nissan Altima SV
I have a 2015 nissan altima that just dies while driving then needs to be Jumpstart, it's like the alternator is not charging the battery,but I get a reading of 14.2 volts from the alternator,battery is new,once car sits overnight it's like it resets and starts right up
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That sounds like a connection issue and not a bad component. Go over your power and ground cables, make sure everything is clean and tight.
Tromeo907
Thank you will check,this thing is driving me crazy
Tromeo907
OK had check engine light on said bad cam sensor replaced both and now the car will not even start, any help would be appreciated
VStar650CL
Technical Expert
Did you use OE sensors? Cheap aftermarket stuff is a plain bad idea, and even good aftermarket stuff often won't work right.
Tromeo907
Aftermarket cheap ones
VStar650CL
Technical Expert
Put the original exhaust cam sensor back in, those rarely quit (I assume you got a P0340 and not a P1078). Replace the intake CMP with an OE sensor and it will probably be fixed. If it isn't, on QR's sometimes the ECM gets confused and blames the cam for the crank or vice versa, so try a new CKP.
Tromeo907
OK will try po340 is the code I got
Return to “5th Generation Altima Sedan (2013-2018)”
