und1974 »
https://forums.nicoclub.com/und1974-u270488.html
Sun Dec 25, 2016 10:37 am
If I am not mistaken the 2015 Altima has what Nissan calls an Accessory Service Connector. There are two of them, one on each side of the car. In the 2016 Altima it is located on top of the ODB port. On the passenger side it is behind the glove box and a bit difficult to reach. You can purchase a special Accessory Service connector plug which has various wires such as Ground, +12, Ignition +12, and other signals. The part number for the connector is:999Q9-AY001. (Be careful because there is an older version with the part number 999Q9-AY000. It will work but the various wire signals are different.) You can look up any of the Nissan accessory installation instructions and they will show you the connector and its respective signals. One more thing. The drivers side connector, on the 2016 Altima, is attached to the top of the ODB port with form tape. You can remove the tape and bring the connector down to see it. On the passenger's side YOU CAN NOT remove it as it is connected to a piece of the framework behind the glove box. If you decide to use it you'll have to get you hand up under the dash and behind the left side of the back of the glove box.
