2014 Versa note steering controls
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
kruuth
Does anyone know where you can get the steering controls for the radio/bluetooth? Are the controls the same as the 2013?
ezb57e
How about the dealer? A junk yard steering wheel?
kruuth
Is there a design difference between the 2013 and the 2014? I'm trying to get a straight answer from a dealer but so far the 4 local dealerships don't really want to talk to me?
kruuth
Ok I installed the steering controls but I'm not getting anything out of the radio harness. Is there a place I can tap off the steering wheel and run to that? According to the FSM it comes from the BT control unit in the back of the car, which is a tough run. Is there a place to get to the wires near the steering wheel?
kruuth
Ok, I've stuck the controls in, and I followed the instructions that someone posted about connecting the controls, but I think that some difference is there in the 14 note. I'm having trouble figuring out what I did wrong. Could someone post a picture of their clock spring connectors if they have the steering wheel controls?
kruuth
Figured I'd post this...the wires in the harness are not the same as what is in the FSM....it looks like ground is the light blue/silver wire, and switch 1 is dark blue. I am still working on switch 2. I tried the black wire, which is under the blue wire, but the resistance is jumping all over the place. Anyone else tried testing the wires in here?
kruuth
Ok...finished:
Looking on the harness there are 3 wires:
Ground:Light Blue/Silver
SW1:Dark Blue
Sw2:Rec/Blue
Happy modding !
AJVersa
Car: 2009 Nissan Versa S Hatchback
You figured it out. :mike Good for you. Doing something no one thought could be done. This is how moding (Hot Roding) got started. If the wheel hadn't been invented, would we still be hauling things on our backs?
Someone has to have the guts and smarts to try something new.
Congratulations my friend, your an ace in my book.
Return to “Versa Technical Discussions”
