Well I replaced the TXV, evacuated the system, and charged it, but weirdly, it worked the best with only about 9 oz in the system. The pressures were good and the vent temp was around 40 degrees. I'd never seen this car perform this well in the last month since I've owned it.
https://youtu.be/W9jijgv3Erc
and
https://youtu.be/XeG_mAwQ1yc
I continued to add refrigerant until the can was empty (12 oz). By that time, the vent temp came up to around 43 degrees from 40. I already had a bad feeling... Even still, I put the next can on, purged the line and opened the low side valve back up. The first oz went in pretty quick. I went and checked the vent temp and saw that it was climbing up still, but I continued to add refrigerant knowing it was only at 13 oz or so. Took about 5 minutes and a hair dryer to get another oz in the system and then it kind of stalled. Now the low side pressure had come up a bit and the vent temp had climbed up considerably.
https://youtu.be/BxzI6pJuS_k
I shut the car down, took a shower and then hit the road. The car started blowing semi-cool air within 30 seconds or so (which it never did in the past), but it still wasn't cold like a normal car. We drove it for 6 minutes on surface streets before we had our first stop. By that time, the vent temp was down to about 45 degrees. Again, this is a feat that this car has never performed before. We parked the car for 30 minutes and then drove another 4-5 minutes before the next stop. We got to around 45 degrees by the destination, but I left it idling in the parking lot for almost 10 minutes and by that time the vent temp was up to 62 degrees. Keep in mind that it's only about 90 degrees outside with 11% humidity. It's definitely better than before, but not what it should be. Could this be a weak compressor?
Starting to wonder if I'm dealing with multiple issues. I'm thinking that this system had a problem before I bought it and someone tried to fix it and only made things worse. I'm basing this on the fluorescent yellow oil that I'm seeing in this system. To me this means that someone had a leak (probably a very slow one) and they stupidly added a can of oil charge so that they could try and locate the leak, but in the process they may have overfilled the system with oil which is now creating a headache for recharging.
Additionally, I noticed the bottom port of the TXV was very lightly blackened. I don't know if these Nissans are like Fords and if that's the black death or if this is somewhat normal, but I'm wondering if that's an indication of a worn compressor as well. If this is true, does this mean that I need the system completely flushed, compressor replaced, evacuated and charged? Are these Nissans typically this bad at 59K miles?
