2014 Rogue Weird sound from engine room
alexkang
Car: Nissan Rogue 2014 SL
My car just starting weird sound from engine room.
I have a youtube link.
If anyone know what is the problem, Let me know.
Thanks.
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Sounds like a pulley in the serpentine belt path, probably the belt tensioner. If its still under warranty take it to the dealer and see what they say.
If not try spraying a little bit of WD 40 into the back of the tensioner, then start it up and see if the noise has changed or gone away. If it has, that's an indication the tensioner is going bad. If the noise is still there shut it off and repeat with the other pulleys in the belt path. Bearings dry out over time, and sometimes you just get a bad one to start with.
darylzero
I concur with Rogue Jarhead.
Spray WD40 or water or the belt and see if the noise goes away.
How many miles on your Rogue? Was the car warmed up during that video? Has your belt ever been changed?
Weird things happen when it starts getting cold outside.
ras_oscar
Car: 2012 Nissan Rogue AWD
Cheese, Guys. You must have gotten the super deluxe rogue to get an entire ROOM for your rogue engine. Mine only came with an engine compartment ;)
alexkang
I replaced drive belt than the sound was gone. but a year later starting again. I will replace Belt Tensioner(11955-4BA0A) this time.
Thanks. for your comment.
Return to “Rogue Forum”
