SERVICE BULLETIN
Classification: AT13-021
Reference: NTB14-019
Date: March 21, 2014
2014 ROGUE; MIL ON WITH DTC P2765, P0500, P1574, P1715 OR P0720
APPLIED VEHICLES: 2014 Rogue (T32); APPLIED TRANSMISSION: CV T8
IF YOU CONFIRM
The MIL is on with anyone of these DTCs alone, or any combination of any of DTCs:
• P2765 – CLUTCH B SPEED SENSOR
• P0500 – VEH SPEED SEN/CIRC
• P1574 – ASCD VHL SPD SEN
• P1715 – INPUT SPEED SENSOR
• P0720 – VEH SPD SEN/CIR
And
• Moisture and/or corrosion is present on or around the Secondary Speed Sensor pins.
ACTION
a. Remove the moisture from the Harness connector with CRC Q (or equivalent) electric cleaner.
b. Replace Secondary Speed Sensor.
