If I do that, after 5 minutes the car warns it will turn off and then 1 minute later it turns off.Rogue One wrote:There is an off position for the lights on the turn signal stalk. As for turning on the radio, push the start button without stepping on the brake pedal. To turn it off push the start button twice.
They did add a way for that, just push it to the mist position a couple times really fast and they should raise up and stay in the replacement position. Car has to be on or within 1 minute of turning it off though.Ferrisfan wrote:I've also wondered if there is a way to turn off the power with the wiper blades at the top of their stroke so I can bend the arm away from the windshield (for washing, applying Rain-X, changing the blades, etc.).
Thank you for that! I guess I had never watched that video all the way through!tsumeone wrote:They did add a way for that, just push it to the mist position a couple times really fast and they should raise up and stay in the replacement position. Car has to be on or within 1 minute of turning it off though.Ferrisfan wrote:I've also wondered if there is a way to turn off the power with the wiper blades at the top of their stroke so I can bend the arm away from the windshield (for washing, applying Rain-X, changing the blades, etc.).
