Using the recirculate function on the HVAC system, without the A/C being engaged to dehumidify the air.
Failure to remove as much snow as possible from shoes before entering the car, resulting in moisture buildup
Failure to remove wet floormats from the car in order to dry them, resulting in moisture build up
Keeping windows open, rather than using the HVAC system (on the A/C setting if necessary)
also, with the recent addiction to improve MPG's a lot of people are forgoing using the A/c function and simply recirculate the moisture-rich air. bad move. all thats doing is causing moisture to build up inside the car.
I have enough experience to know that the issues listed above are not the problem, unfortunately. I do not use recirculate. This started before the snow and does not generally occur when it has snowed. My floor mats are all season and have never been a problem before. The windows I do roll down in the summer, but not the last few months. Also I have to keep the AC function on because it "might" help the moisture according to the dealer.
With that being said, this is not a little bit of water on the windshield. It is a very large amount that I find next to impossible to be owner mistake unless I drove two hours through a rainstorm with recirculation on or emptied a hose into my car and let it sit in the sun with the windows shut. The window becomes completely saturated.
I understand the MPG might be placebo, I just thought it was something that should be noted.
Regardless of that, is it possible that the clogged filter would trap moisture in the car and I may be correct? When I say the air flow is incredibly improved I am not exaggerating.
If none of these situations is applicable to you, then you may want to explore the possibility that the heater core is leaking, or is building up moisture due to backed up drip-tube. If the cowl or evaporator box is loaded with leaves or other debris, this can also cause an overwhelming amount of water to flow through the evaporator box during rain, causing the carpet to get wet.
The dealer supposedly checked the heater core and ran water through the system. The car was left there for 5-6 days and the problem did not occur. I tried to explain to them it is only after specific circumstances, usually when it has been driven and then sits. It was like the moist air from outside would enter the car and had no way out. This is without the recirculating feature being on. Ever.
The best advice I can give is to request a meeting with the factory rep for your area. You can make the request through the dealer, or by calling Nissan at the number listed in your owner's manual. Not sure what they (Nissan corporate) can do for you, but at this point it doesn't sound like you are going to get anywhere with the dealer.
Thank you, I might try this when I can prove I have been problem free after a rainstorm or two. Your theory regarding the leaves if very possible as I park outside and there are trees around. What I don't understand is why the dealer wouldn't mention it could be that the air filter was shot - if leaf particles were clogging it up you think they would have mentioned it!
