2014 Rogue radio song indicator
rebound2
Car: 2017 NISSAN MURANO SLAWD PLATINUM
It doesn't work very well. I usually is displaying the song previous to the current one playing and if you change stations and return to the station then it doesn't show anything and continues even after the song is over. Anyone else experience this? The one on my 08 Maxima wasn't great either but not as bad as this. The reception in this radio also varies from being good to having a lot of static.
RicerX
Car: '20 Titan Pro4X
Is this the radio readout on the radio itself or the one that's selectable between the speedmeter and tachometer in the gauge cluster?
rebound2
The one on the radio screen - I don't tend to look at the one between the 2 big gauges because it's usually on another mode - I'll check that one out.
RicerX
See if they're out of sync. You may have a defective head unit if so. I would consider bringing it in since it would be covered under warranty, especially considering the reception issues.
rebound2
Hmmm I looked at the one between the gauges and it's in sync with the one on the radio screen - I'm taking it in because the driver side door handle switch isn't always working right so I'll have them look at it.
RicerX
Gotcha. Let us know how it goes!
Return to “Rogue Forum”
