Yeah, checked there. I am hoping they're in there, but the labeling is garbage. I'm going to call the dealer today.Pookh007 wrote:Try left side of dashboard while you open driver's door. there is a cover you can pool out and bunch of fuses there. May be this can help.
this is not a fuse issue. a fuse either send power, or it doesnt. if the halogen bulb works, than the fuse is fine.AudiSportB5S4 wrote:Question stemming from: HID kit on the car and one corner is flickering the bulb and the other isn't. The side that is flickering a bulb powers a normal halogen headlamp without issue. Very strange I just want to check the condition of the fuse for the heck of it. Any ideas? Ballast/bulb work perfect on other side.
Gotcha. Yeah, I figured because I know what a fuse is/does so unless it wasn't powering at all I wouldn't have expected it to be bad. My hunt for the fuse was fueled by some people stating sometimes you have to up the fuse to a diff amperage if the HID is flickering. Then I felt like it was a manhunt to try to find it because I've never had trouble finding a headlight fuse!ImStricken06 wrote:this is not a fuse issue. a fuse either send power, or it doesnt. if the halogen bulb works, than the fuse is fine.AudiSportB5S4 wrote:Question stemming from: HID kit on the car and one corner is flickering the bulb and the other isn't. The side that is flickering a bulb powers a normal halogen headlamp without issue. Very strange I just want to check the condition of the fuse for the heck of it. Any ideas? Ballast/bulb work perfect on other side.
your problem is either the bulb, or the ballast. searching for the fuse is a waste of time. you can try a wiring harness, capacitor, or a new kit.
thats a crock of shyyyt. a fuse doesnt flicker power. its either on, or its off. no other options. in fact a fuse doesnt get in the way at all, until to much power goes through it, and the metal melts.AudiSportB5S4 wrote:My hunt for the fuse was fueled by some people stating sometimes you have to up the fuse to a diff amperage if the HID is flickering.
Well I can rule out number 1 because I tested it on another car and it works well. I have a feeling that number 2 is my reality, but what blows my mind is that it worked perfectly fine for two weeks. Just kinda hesitant to believe that out of nowhere I need to buy something to support it. and 3, this is my g/fs SUV, 100% stock including radio. I will report back on whatever does fix it because I drive myself insane until I find the answerImStricken06 wrote:my money is on:
1. faulty HID kit (bulbs, ballast)
2. you need a wiring harness due to loss of current
3. you have a system in your car that shut off the bulb current/flickers when you fall under 55watts and you need capacitors (warning cancelers)
Ah okay. I just ordered a wiring harness from DDM to run to the battery and add in a relay, I'm hoping this fixes it.ImStricken06 wrote:some cars have a system inside that detects lower wattage consumption as bulb faults. (thats what #3 was referencing).
did you try swapping the kits opposite of one another?
