That is good info ^... Personally I dont think that 2" over a sedan is all that great. It is just "ok" to me... What I dont get is why Nissan couldnt up the mileage without making this thing so low... The forester is a whole 1.3" taller and has the same sized engine and a cvt WITHOUT all the fancy schmancy underbody plastic and plastic rear hatch door and aluminum hood and "rear muffler spoiler"... And it gets pretty much the exact same mileage as the new Rogue which has all of that stuff....sprocket wrote:The 2014 Rogue IMO is pretty decent for its segment, and I can understand the shift in ground clearance as fuel economy becomes a bigger priority. I don't think the new Rogue has bragged about its ground clearance, its focus is definitely more for on-road with decent (for its segment) off-road capability. Considering that most sedans typically fall around the 5-1/2" ground clearance category although there are some exceptions to that rule, I think the Rogue coming in at almost 2" additional clearance than typical sedans is decent.
How it stacks up.
Ground clearance (highest to lowest):
Forester (2014+) = 8.7 (non turbo) / 8.9 (turbo)
CX-5 (2013+) = 8.5
Escape (2013+) = 7.9 ; reduced -0.5" from previous model 8.4
Rogue (2014+) = 7.4 ; reduced -0.9" from previous model 8.3
Tucson (2010+) = 6.7 ; reduced -1" from previous model 7.7
CR-V (2012+) = 6.3 (FWD) / 6.7 (AWD) ; reduced -0.4" on FWD from previous model 6.7
RAV4 (2013+) = 6.3 ; reduced -1.2" from previous model 7.5
Since this discussion is about ground clearance, I figured it was reasonable to arrange fuel economy rankings by AWD instead of FWD, I also picked only one engine which I thought was both best-case EPA and had HP/TQ ratings close to the segment, which is why I excluded the CX-5 and Tucson 2.0L.
Fuel economy (highest to lowest):
Rogue 25/32 (AWD), 26/33 (FWD)
Forester = 24/32 (non turbo) / 23/28 (turbo)
CX-5 = 24/30 AWD, 25/32 FWD ; w/ 2.5L which has more comparable engine output to competition
Escape = 22/30 (AWD), 23/32 (FWD) ; w/ 1.6L Ecoboost with best EPA MPG (vs 2.5L or 2.0 Ecoboost)
CR-V = 22/30 (AWD), 23/31 (FWD)
RAV4 = 22/29 (AWD), 24/31 (FWD)
Tucson = 22/25 (AWD), 21/28 (FWD) ; w/ 2.4L which has more comparable engine output to competition
It all depends on what is your priority I suppose. I am looking forward to my 2014 Rogue on order.
Don't you have a Santa Fe with .... 7.3" of ground clearance? I think I just put out your fire, haha!ImStricken wrote:good info. i will never buy another rogue, so this is more fuel to my fire lol
i'm not on fire about ground clearance. i just said its one more reason to not want the new rogue.sprocket wrote:Don't you have a Santa Fe with .... 7.3" of ground clearance? I think I just put out your fire, haha!ImStricken wrote:good info. i will never buy another rogue, so this is more fuel to my fire lol
Yeah from what I've noticed, they don't offer them on crossovers with 1 piece bumpers (basically most crossovers) which is more of a "front fascia".. The trucks and SUVs with a two piece (bottom and top) have them because all you do is swap out the bottom... If you got one for the Rogue you'd need to do a custom one. Cutting the bottom half of the Rogue's fascia off and replacing it with metal.ImStricken wrote:put it this way, when i was fixing my car and waiting on payment from the insurance = i research not putting my OEm bumper back on. i wanted this type of bumper; but none was available for our car
thats exactly what i was gonna do lolfollowingnfront wrote: If you got one for the Rogue you'd need to do a custom one. Cutting the bottom half of the Rogue's fascia off and replacing it with metal.
Pioneer it and Ill do it too lolImStricken wrote:thats exactly what i was gonna do lolfollowingnfront wrote: If you got one for the Rogue you'd need to do a custom one. Cutting the bottom half of the Rogue's fascia off and replacing it with metal.
