2014 Rogue Awd starter location
aquapong
Car: 2014 Nissan Rogue
I’ve been searching for hours. I’m convinced it doesn’t exist. I’ve looked under the engine compartment from the right front wheel and pulled apart the air intake to try to get down from above. Two different videos give me different places. Where is it??
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Do you have a 1st or 2nd gen model?
aquapong
2nd gen. Not the select. I’m thinking it’s down the front like an Altima? I was going to look again tomorrow.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yes, it's down in front just like an Altie.
aquapong
Well I did find it down the front. I could not get that 16mm bolt off however. I’m admitting defeat and having it towed to the shop. But for those who might follow after me. It is in the front.
VStar650CL
Technical Expert
The only good way to get the bolts is with a long extension from the lefthand wheel well. There's not enough clearance to the radiator to get torque on it any other way.
Return to “Rogue Forum”
