Took everything apart, verified the gears were not stripped and the baffle door got moved and the starting location wasn't kept but not a big deal after spending the next few hours messing around with it. The actuator has a gear with a slice out of the base that meshes with the baffle gear, when the baffle gear peg rotates around the peg needs to meet at the right spot.
That's where my problems start, the actuator and baffle gear feel like they are separating. I screwed the actuator back in place and adjusting the temp I let my fingers float along the top of the gears, not sure the peg is causing the problem at this point though. I questioned if some of the plastic was broken so I took some good photos to share, as well as the actuator. Not sure I'm missing if something is broken or missing that jumps out at some of you other fine folks? Decided to call it at midnight and post in the morning, everything is fairly easy to access and the local shops wanted to charge a thousand bucks for this replacement, haha no thanks dudes. I've done such jobs before cheating parts out of the way to get your hand or a small child's hand up into the dash and replace some plastic with other plastic. This one has me stumped and could use some fellow QX80 owner advice on how to fix this without spending the money a shop wants to take out the whole dash? Seems obtuse atm, but then again, I've haven't fixed it, yet
Really hoping somebody has some good info or advice to help me out of this ditch.
