Poorman148 »
https://forums.nicoclub.com/poorman148-u299072.html
Mon Aug 14, 2023 12:41 pm
I took the lower panel off, the one that houses the Jack. Then I loosened the right lower that houses the tools . Then I took off the top panel that you bolt the seatbelt too. I then looked behind them all and saw the hoses. But I couldn’t see where the hoses terminate. Is it the large hose that is the problem or the small hose? I am a 76 year old carpenter and when I tore it apart this far, and couldn’t see what I needed to see I got nervous and closed it back up. How close was I? I couldn’t see anything that would lead me to think I was close. BTW I really appreciate you trying to help me. I want to sell this but I couldn’t sell it unless I knew it was fixed, should I try again? This can’t be done from the outside? Where does drain out of the tube? I can see the front sunroof drains out by the left front tire.
