2014 Q50 Hybrid Keyfob
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
shepscrook
Car: Infiniti Q50S Hybrid
So I just picked up a used Q50 Hybrid and one of the keyfobs doesn't work. Any way that I can easily get this replaced or is the only route to go through the dealer?
audtatious
If the battery is OK it may need to be re-programmed at the dealer. If the fob is bad then you can get one on ebay for cheap but will still need Infiniti to cut the key and re-program it to the car.
Return to “Infiniti Q50 / Q60 Forum”
