2014 Q50 engine swap
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
zmanq50
Car: 2008 G35X
I need to change my engine, no warranty car was purchased as a salvage. If I purchase an engine off the internet will I need the ECU of the car it came from or can I replace any sensors from my existing engine without needed the donor ECU. Thanks in advance
RicerX
Car: '20 Titan Pro4X
The safe option would be to get the ECU of the donor car, but I don't see how you couldn't mate the motor to a new ECU.
Service guys swap ECUs or flash them for various reasons all the time, but I'm unsure of the procedure to help with that. You can always look at the service manual for the Q50 located at: Http://www.nicoclub.com/fsm
smola
Car: 2015 Infiniti QX80
2016 Infiniti Q50 AWD 3.0 Premium
2014 Corvette Stingray
Change engine only, leave Old ECU. I have changed vq35 engine without any problems.
Return to “Infiniti Q50 / Q60 Forum”
