2014 pathfinder gas gauge problem
katillidie
Car: 1990 infinity m30
93 s13 coupe vq35hr swapped
96 s14
2003 m45
2000 frontier
so I have had my 2014 pathfinder for 2 weeks the miles till empty and the gas gauge are not reading properly.. first time I noticed it was exactly one week after purchase, the miles till empty was showing 15 miles and fuel gauge at 0 when randomly the miles till empty jumped to 120 miles and fuel gauge was now showing half tank... so I kept driving and it was fine.. when it got close to empty I filled the tank... to $50 bucks total... weird cause the 2012 Altima was around $65 anyway while driving to work the next day about a 5 mile ride one way.. the gauge dropped from full to half and lost 60 miles.. I know its hard to pay attention to the gauge while driving but if u do it jumps all over... today I took it to Nissan. the tech is a friend who said he had one last week also but CND so he sent her on her way, but since I was also complaining he decided to call Nissan tech line... well what he told me next infuriated me... the tech line rep first asked why he was calling on a vehicle with only 400 miles.. then said they are aware of the problem but do not have a fix yet... he stated that there is an issue with the miles till empty screen but not the gauge... well correct me if I am wrong but the sending unit tells the ecu how much fuel is in the tank which also tells gauge where to read.. then the ecu makes a guestamite to how may miles till empty... so if the gauge is all over the place along with miles to empty. makes me believe that the sending unit is not working properly. Then before the tech got off the phone with tech line, the rep said specifically not to order any parts due to no CEL light being on.. im sorry but to me this is a safety issue.. if the gauge reads we have enough fuel while driving, but it doesn't cause the sending unit is reading improperly, we then run out of gas and get rear ended. who takes responsibility? I just got off the phone with Nissan consumer affairs and submitted a claim. should hear back tomorrow 2/27/2014
Walt_Trident13
Car: 2014 Nissan Pathfinder SV
I realize this is an old post, but we just purchased a used 2014 Pathfinder (17,000 miles) and my wife mentioned having the same problem with the gas gauge. Did you ever get this resolved?
Thank you.
katillidie
96 s14
2003 m45
2000 frontier
No unfortunately they have not fixed the issue... They keep telling me they are working on a fix... Its been a few months since i last called them.. We have been dealing with it.
katillidie
96 s14
2003 m45
2000 frontier
just received a phone call from a friend at a local dealer... they replace the cluster.. if ur miles to empty is different then ur gas gauge! ie mine yesterday was showing 1/4 tank and zero miles to empty! they replace the complete cluster.. i take mine in wed
ineedjules
Car: Pathfinder 2014 Platinum
I have a 2014 Pathfinder Platinum. A couple month ago I got the cluster replaced to attempt to fix my low fuel and miles to empty to read correctly. It seems once I get to low fuel, it gets stuck. This past Friday my low fuel came on at 32 miles to empty so I got $10 which filled it right under half a tank. The gauge moved but it stayed at 32 miles then continued to go down to 18. I got nervous and filled the tank. Once I did this it corrected itself it. I already called it in for service so its there now and im waiting to see what they will do next.
UGHHHHHH
