2014 Nissan Rogue SV - issue with headlights
bios
Recently I replaced headlights with HID. Was working fine for 2 month. Now , here is what happening:
- both headlights work fine when engine is on
- when I turn off the engine driver side headlight goes off (suppose to stay on for few minutes), passenger side stays on as suppose to
what could be the problem?
Thank you!
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Did you install aftermarket HID's? the problem is probably with the electronics of them.
bios
Yes, aftermarket.
By the way, I forgot to mention that I plugged back its original light bulb, but issue still persist.
So it's definitely not HID.
04pathse
bios wrote:Yes, aftermarket.
I see, well your vehicle should still be under factory warranty, correct? if so I would just have the dealer figure out the issue.
But, you probably shouldn't mention that you had previously installed aftermarket HID's or they might void the warranty on the repair.
bios
Yes, it still under warranty. That`s my backup plan.
I just want to find out with your help what could be wrong.
Return to “Rogue Forum”
