First off, hey all (any who are reading this, anyway) new here. Joined because I have 2 nissans at home; '08 Versa and '07 Murano.
Perusing this forum because my family jsut got bigger and I can't get past just how practical a minivan is.
I was hunting for quality/reliability complaints. The Quest is my top contender atm.
So I looked through this thread and read that review, and honestly it leaves a sour taste in my mouth. There was only one valid point about the doors; for the rest I'm rasing my
on to the A/C adapter thing. My Murano is set up the same way; the Car has to be on or set to Acc at least, for the A/C to flow. It's a simple fix if you want constant 12V, but it will require a single wire splice. I'd be happy to explain if you want
Having constant 12V to an A/C outlet is a risk for the owner, if you leave something plugged in it'll drain the battery, unless there's a timed switch or relay involved to cut power at a given limit. I know I'm forgetful, and count it as a plus that they wired it through a "switched on" as opposed to constant.
