With 167K there's a pretty good chance the tech is right, but you can test the clutch yourself by putting the IPDM into Auto-Active Test mode. See PCS-11 here:
https://www.nicoclub.com/service-manual ... %2FPCS.pdf
If the clutch clicks audibly during AAT, it means your first instinct was correct and something besides the compressor is the matter. If it doesn't, then you know the clutch is shot or there's an electrical issue like a blown clutch fuse. Fuses rarely blow for no reason, so if it's the latter, chances are the clutch is shot anyway. The IPDM could also have a bad A/C Relay (requires replacing the IPDM).
If the clutch works in AAT, other possible causes of no-operation are:
* Dead refrigerant pressure sensor
* System has refrigerant but is overcharged
* Ambient sensor is open circuit (in the grille)
* Intake sensor is open circuit (on the evap, but there's an external connector on the side of the HVAC box)
* Cabin sensor is open circuit ( near the driver's right knee)
* Bad A/C controller (A/c Auto Amp)
You can get the skinny on your whole HVAC system here:
https://www.nicoclub.com/service-manual ... %2FHAC.pdf
If the compressor does need replacement, the simplest way to wiggle it out is to take the front two subframe bolts and the nose mount loose, to let the whole thing tilt forward. Doable without a lift, but not easy.
