2014 Coolant replacement
CapeCodChips
Car: '14 Nissan Rogue SV Gun Metal Grey
When do you replace the coolant on a 2014? I've heard some coolants are lifetime.
I can't find coolant replacement in the service manual.
Prestone says it's OK in all engines. OK to flush and fill with Prestone?
Rogue is a 2014, 33 months old and 102,000 miles.
Thanks
No need. Should be "lifetime" - but I'd recommend replacing it when you do hoses.
Also, make sure you use the same color coolant - grab it at the dealer, to be on the safe side. You're putting some miles on that car! :)
darylzero
CapeCodChips wrote:When do you replace the coolant on a 2014? I've heard some coolants are lifetime.
Thanks
Do not use Prestone.
Page 11 of your Service & Maintaince Guide states:
Engine Coolant*
Replace coolant at the specified in-terval. When adding or replacing coolant, be sure to use only Genuine Nissan Long Life Antifreeze/Coolant
(Blue) or equivalent with the proper mixture. (Refer to the Owner’s Manual to determine the proper mixture for your area.) The recommended ser- vice interval of the factory-fill coolant is 105,000 miles (168,000 km) or 7 years, whichever comes first. Subsequent replacement of Genuine
Nissan Long Life Antifreeze/Coolant (Blue) should occur every 75,000 miles (120,000 km) or 5 years whichever comes first. NOTE: Mixing any other type of cool-ant or the use of non-distilled water will reduce the recommended service interval of the coolant.
Return to “Rogue Forum”
