Hey guys,
Just got a 2014 Altima. Front right turn signal is out. Bought two new LED bulbs to replace the old bulbs. Tested both LED bulbs on the left side of the car and they work great, super bright and no hyperflashing. Tried putting the new bulb on the right side of the car, and it wouldn't work. I thought maybe that socket was bad. I took the socket from the right side of the car, moved it over to the left, and that socket worked with one of the bulbs on the left side of the car. So the socket and bulb both work, but no turn signal. Been thinking it was a fuse problem, but I can't find a fuse for any blinkers. I thought maybe the FR Fog and Signal were on the same fuse being so close together but that fuse looks good. Tiny bit of what looks like corrosion on the blades on the outside but the inside metal bit looks to be closed and not blown still. And all the fog lights work fine. Any idea what's wrong here?
On top of that, my right headlight is really dim compared to my left. This was the case both with the halogen bulbs that came with the car, and with some new LED ones I just bought to try and fix the problem. Checked that fuse too and that fuse is fine for the FR headlight. Someone at auto zone said possibly the halogen bulb was positioned wrong, got really hot and melted against part of the housing causing it to not let as much light through? Or melted on some type of reflector or something that's inside the housing. So possibly I'd need a new housing... If so I would greatly benefit from instructions and advice on removing the headlight assembly / housing to check for this problem.
EDIT: Found this YT video for housing removal. So I know how to do it now but I don't know if that'll fix my problem or not. If anyone has any comments on what would be causing the dim headlight, still need comments on that. (
https://www.youtube.com/watch?v=8fSZ84RorrY )
Cheers guys!
