Greenwood$ »
https://forums.nicoclub.com/greenwood-u312092.html
Sun Feb 04, 2024 5:19 pm
Sunday Nite Recap
- rechecked all newly installed engine mounts, all look ok
- rechecked torque on the bolts for these all are either at a smudge above what is called out. for the sake of verifying, do you have the torque for the bolts that hold the largest mount in place. This is the one that ties into the engine top plate mentioned earlier today. The top nut I have set at 76 lb ft and the two long bolts at 37 lb ft. With the engine running in park, i can get my hand on that mount and do not feel any vibration at all
- ordered (4) new plugs and (1) coil for replacement and testing purposes
- the vibration comes through on the passenger side, up from beneath both seats. I had replaced both exhaust mounts within the last month
- A new observation, is that when I back out of the garage and turn the wheel, the rpm dips and the vibration to the wheel increases. When back straight and rpm rises slightly goes back to the new normal level
- wife says that even after warmed up, the vibration is felt especially in that 1200 to 1250 rpm range. Also occurs when lifting of the gas at say 20 mph to coast to a stop sign as the rpm decreases to that 1200 level and eventually down to 700...not as intense as when cold
- received and printed out ground test document, though admit that without a sketch not sure what I am doing and where the block ground as an example is located
Other things wife has chipped in
- from reverse to drive with brake on, seems to take a sec longer for drive to engage than what we have been used to
- she mentioned just today that when she was driving a few weeks ago, a warning message flashed for a second then disappeared. she did not see what it was for and does not exist now. Zone read for codes and none came up and no CEL ever on this since new
The vibration started last year in colder weather then when back to 70 deg and up disappeared
I am not a trained tech. I have worked on cars for 40 plus years. Our favorite of all time was the Mercury Villager van with the Nissan 6 cyl drive train. Timing belts and tune ups, a few cv axles and went to the JYD at 300,000 + miles
