Thanks for the ideas!VStar650CL wrote: ↑Sun May 01, 2022 9:55 pmRun the window all the way to the bottom, then all the way to the top and continue to hold the switch for 3~5 seconds. That should re-time the Auto function. If it won't take because of the interruptions, pop the Master Switch loose and disconnect it for a few seconds, then try again. If it still won't take then the problem is most likely a bad motor or a binding mechanism causing the motor to draw too much current, but could also be a bad Master Switch or a cooked ground terminal at the Master. If the ground checks good, to find out if it's the Master or something south, pop the door panel and disconnect the motor, then put a bulb-type test lamp across the motor terminals and work the switch. If the light stays lit then the problem is motor current, if it cuts out then the Master is bad.
