2013nissanrogue wrote:
The Fuel display that's telling you how you doing on gas is very very inaccurate on my rogue. If you want to find out what your really doing on gas per gallon. Fuel up a tank of gas and note how many gallons it took. Now clear either tripe A or B and see how many miles you got when your almost out of gas.
i think you did it in the wrong order.
You should first reset trip meter on previous gas stop, put full tank in
Wait until next gas station visit, fill up until full tank, and use the trip meter and the amount of gas put in to calculate the mpg
If you do it the other way around, it will not be accurate because you can't really tell how much gas left in the tank even if they show up the same on the meter
