DTASFAB »
https://forums.nicoclub.com/dtasfab-u223076.html
Fri Apr 18, 2014 1:09 pm
Jim Harte Nissan, part of the Harte Auto Group in NY and CT. This is the same dealer that changed my oil without my knowledge or consent a few months ago, then tried to deny it. NissanUSA sent me a $200 gift card for my trouble.
This time, I wrote specifically on the envelope I used to drop off the key, "Do not perform any unrelated work."
The only reason it was there is because the rear hatch wouldn't lock, and they replaced the hatch lock under warranty. They also did a multi-point inspection, including checking the brakes, alignment, and battery, despite my instruction to not do anything unrelated to the hatch lock. When I finally got my truck back, the electronic data in the dash had been completely cleared. The radio was ok, because the head unit apparently has its own backup battery. This has happened on multiple occasions and it's really getting annoying. They had no reason to even pop the hood open on this visit.
I don't see why they can't connect an alternate power source to the OBD II port under the dash board when disconnecting the battery. Even if the battery is getting replaced, they should be doing this. My regular mechanic has done it on a 1996 Camry for me. Why can't it be done on a 2013 Rogue? The answer is, it can be done, because they did it once... just not the other 3 times they've disconnected my battery for one reason or another in the 8+ months I've owned the truck.
Part of the problem is they get a new service advisor every 2-3 months, so I'm always dealing with a different person. Their sales floor has a near 100% turnover rate every 3-6 months as well from what I have read online and observed myself. Obviously their business model is flawed somewhere.
I've heard much better feedback from two other local dealers. It will be a bit inconvenient, but I will be using one of them for my next service. I'm so sick of Jim Harte.
