Hi, I have a 2013 Rogue. never had problems until the other day I drove it to work fine, but after work it would not start.
I had it towed home and have found that there is no gas and no spark. when i turn the key i can hear the fuel pump and there is 12v at each coil. I also checked all fuse I know of and replaced the crank and cam sensors.
Has anybody else here seen this problem ? could it be the computer ?
Thanks so much in advance, this problem is driving me crazy !
I forgot to mention that the Rogue does crank over.
