brokesmoke wrote:I did not actually. I'll look at that. I was just trying to find something to increase the overall brightness and figured bypassing the factory OEM hids with an after market 55w hid kit would be the quickest and easiest solution.
yes there is a knob just above the left knee, on the dash. it will be a wheel going vertical with numbers 1, 2, 3, and i think 4? that will raise and lower the headlights internally. most people dont read their manuals and have no idea what that is. they clean their car, use a rag to wipe down the area, and end up dropping the headlights down.
anyway, your theory that aftermarket kits are somehow brighter is wrong. HID kits come in 35watts or some come in 55watts. the stock bulbs are somewhere near 4300k-5000k. that is the purest white light you can get. bluer, only means less light output. so in fact if you replaced the stock hid kit, with say 4300k - 6000k - you wouldn't be actually upgrading. also most aftermarket HID kit bulbs are not sized appropriately length wise for the reflector bowl; giving large hot spots or simply sending the light upwards.
-believe me, aftermarket HID kits are not superior to OEM hid systems.
