ever try and shut off a car, while in drive? lmfao that biznatch will stop so fast - it will whip lash you.kerrton wrote:shuts off the fuel injectors using no fuel
Why is that? I. Wouldd imagine it would just roll until it stopsImStricken wrote: ever try and shut off a car, while in drive? lmfao that biznatch will stop so fast - it will whip lash you.
How is it any different than stalling out?followingnfront wrote:Why is that? I. Wouldd imagine it would just roll until it stopsImStricken wrote: ever try and shut off a car, while in drive? lmfao that biznatch will stop so fast - it will whip lash you.
I believe in many modern cars they are more efficient coasting in D than they are coasting in N:ImStricken wrote: coasting in D, does use SOME fuel - but not a lot. there is still some load placed upon the engine to keep it at the very least able to idle.
the engine creates a TON of drag. coasting in D still uses fuel - just less than if you were on cruise control.followingnfront wrote:Why is that? I. Wouldd imagine it would just roll until it stopsImStricken wrote: ever try and shut off a car, while in drive? lmfao that biznatch will stop so fast - it will whip lash you.
izakly son! lol it will stop really-really short. much shorter than if you simply let off the throttle while driving 65mph.followingnfront wrote:I'm confused... What happens when you turn off the engine of a car while driving (in drive) that causes the car to stop short?
Lol... Im asking what causes it though... How is it different from coasting in neutral? Nothing is propelling the vehicle in either instanceImStricken wrote:izakly son! lol it will stop really-really short. much shorter than if you simply let off the throttle while driving 65mph.followingnfront wrote:I'm confused... What happens when you turn off the engine of a car while driving (in drive) that causes the car to stop short?
Im with you... I notice alot of people with stickshifts drop it into neutral too at all speeds when they know theyre ultimately coming to a stop too... And I never understood that... The whole point of having a stick is having ultimate control... Downshifting for engine braking and immediate acceleration if you need it... Duh... I miss having a manual :-(sprocket wrote:Personally, I don't see any merit in shifting to neutral when driving/stopping.
If your vehicle is in motion and you shift to neutral but suddenly need to accelerate (say to avoid a distracted driver, etc), you've basically disabled acceleration. If you're going downhill, coasting in neutral will not provide any engine braking which to an unexperienced driver, can result in loss of brakes or loss of vehicle control.
While there's less drag when coasting in neutral which in theory means less loss of energy, I've noticed that the instantaneous fuel economy gauge "maxes" out at 75+ mpg when I'm coasting for the most part, until my speed drops low enough for the torque converter to disengage. I feel that leaving it in drive as I coast to a stop is safer and more predictable and doesn't "waste" gas as much as some people may think and has less wear on the brakes.
I've also noticed that the engine actually "idles" lower in drive when the brake is pressed than in park/neutral in my experience, so shifting to neutral actually increases engine idle speed slightly which burns more gas, no? Not to mention the wear on transmission to shift in and out of drive.
To each their own I guess ... I know there are people on both side of the fences when it comes to leaving it in D vs. shifting to neutral when coasting/park when stopped
Sorry, a metal box containing two pulleys is not a transmission. A real transmission has GEARS, plural. Nissan can claim their CVT has "infinite" gears, but in reality, it has one gear that is adjustable.kerrton wrote:And the CVT is a "real" transmission, its just a different design
I still don't understand how it's any different than stalling out.ImStricken wrote:izakly son! lol it will stop really-really short. much shorter than if you simply let off the throttle while driving 65mph.followingnfront wrote:I'm confused... What happens when you turn off the engine of a car while driving (in drive) that causes the car to stop short?
In your first post, you said shifting into neutral while moving is not good for the transmission. But every time you shift, you're actually briefly shifting into neutral while you're between gears. How is shifting into neutral, coasting for a while, and then shifting back into gear causing any additional wear that you wouldn't get by downshifting immediately? The amount of time you spend in neutral doesn't matter if your only concern is wearing out the transmission.followingnfront wrote:Im with you... I notice alot of people with stickshifts drop it into neutral too at all speeds when they know theyre ultimately coming to a stop too... And I never understood that... The whole point of having a stick is having ultimate control... Downshifting for engine braking and immediate acceleration if you need it... Duh... I miss having a manual :-(
WHEN IN GEAR/DRIVE: your wheels are mechanically connected to your transmission. your transmission (when in D/gear) is mechanically connected to your engine.followingnfront wrote: How is it different from coasting in neutral? Nothing is propelling the vehicle in either instance
My concern of damage is for an automatic trans by shifting in and out of neutral in a scenario like yours...DTASFAB wrote:In your first post, you said shifting into neutral while moving is not good for the transmission. But every time you shift, you're actually briefly shifting into neutral while you're between gears. How is shifting into neutral, coasting for a while, and then shifting back into gear causing any additional wear that you wouldn't get by downshifting immediately? The amount of time you spend in neutral doesn't matter if your only concern is wearing out the transmission.followingnfront wrote:Im with you... I notice alot of people with stickshifts drop it into neutral too at all speeds when they know theyre ultimately coming to a stop too... And I never understood that... The whole point of having a stick is having ultimate control... Downshifting for engine braking and immediate acceleration if you need it... Duh... I miss having a manual :-(
you are not supposed to downshift versus simply using your brakes. a clutch is nothing but a big brake pad. now ask yourself, loading up the clutch or loading up the brakes. which is easer and cheaper to change?followingnfront wrote:people who have manuals and dont downshift when coming to a stop, but rather shift into neutral are doing it wrong.
See, I disagree ... you should keep it in gear until you've almost come to a stop and need to press the clutch in. Putting it in neutral may allow the car engine to stall and if that happens just when you're nearing a stop, loss of assisted braking and power steering can be dangerous when it happens unexpectedly.ImStricken wrote:you are not supposed to downshift versus simply using your brakes. a clutch is nothing but a big brake pad. now ask yourself, loading up the clutch or loading up the brakes. which is easer and cheaper to change?followingnfront wrote:people who have manuals and dont downshift when coming to a stop, but rather shift into neutral are doing it wrong.![]()
in a manual car, if you are coming up to a stop light/sign - drop it into neutral, and slow down. down shifting does nothing positive for you - even if your rev-match to reduce strain on your clutch.
its not supposed to stall, by being put into neutral. if that happens, you have a serious problem. by being left in gear, and slowing down - is when stalling becomes an issue. i have well over 100,000miles on a 5 & 6 speed manual btw.sprocket wrote:Putting it in neutral may allow the car engine to stall
I agree with you but what I meant to say is that if you have a car that is ... umm, not in the best of shape that may not idle right, then you can cause the engine to stall out if it's in neutral ... I'm sure you've seen (or been) that guy who is at a light revving it slightly in neutral before quickly shifting in to a gear! I've had to do it before on a friend's late 80's Prelude with a twin carburetor that wasn't quite running right during the winter, had it happen once in college in a late 80's Escort that didn't run right until it was properly warmed up. I don't miss the days of driving beaters but I must say, it was a lot of funImStricken wrote:its not supposed to stall, by being put into neutral. if that happens, you have a serious problem. by being left in gear, and slowing down - is when stalling becomes an issue. i have well over 100,000miles on a 5 & 6 speed manual btw.sprocket wrote:Putting it in neutral may allow the car engine to stall
Im suggesting you use both your brakes and downshifting while slowing to a stop. Revmatch and Drop the clutch smoothly and now youre now in a gear and can simply hit the gas if you need to accelerate instead of having to spend more time shiftiing from neutral to drive (if youre in stop and go traffic for instance).ImStricken wrote:you are not supposed to downshift versus simply using your brakes. a clutch is nothing but a big brake pad. now ask yourself, loading up the clutch or loading up the brakes. which is easer and cheaper to change?followingnfront wrote:people who have manuals and dont downshift when coming to a stop, but rather shift into neutral are doing it wrong.![]()
again, there is no reason to load your clutch, to use it as an additional brake.followingnfront wrote:Hypothetical ImStricken, you are going 60 on the highway... This particular highway has traffic lights every so often (Jersey style lol), and 300-400 feet or so in front of you the light just turned yellow then quickly red... So you need to stop pretty quickly and hit the brakes pretty hard... Do you just use the brake with the clutch depressed or do you hit the brake and then switch out of 6th into 3rd, then 2nd and then depress the clutch at around 15mph?
